johnmayerrr Posted 4 hours ago Share Posted 4 hours ago My 2021 Nissan Niro self-charging headlights aren't very impressive, I must say. Can you suggest any alternatives to the halogen lights? Much obliged Quote Link to comment Share on other sites More sharing options...
Gianni682 Posted 4 hours ago Share Posted 4 hours ago In order to make things better while still staying within the law, you may find a variety of so-called "upgraded" halogen lights online. Have a look around and read reviews where relevant; Halfords would be a good place to start. Since most manufacturers have abandoned the Xenon alternative, LED lamps have quickly become the standard. However, as is well known, it is technically illegal to simply install LEDs into headlamps designed for halogen, so to avoid a MOT failure, it is best to stick with halogen, preferably the best you can afford. It is easy to overlook some characteristics that you truly desire when perusing a new car's specifications list, so before you buy another vehicle, jot down a list of everything you absolutely must-have. A heated steering wheel, LEDs, an automatic gearbox, electronic power brakes, a lengthy warranty, respectable gas mileage, etc. are the standard features on mine. Hopefully, you'll be able to locate dependable upgraded lights. Quote Link to comment Share on other sites More sharing options...
johnmayerrr Posted 4 hours ago Author Share Posted 4 hours ago The headlights on my 2011 Kia Promenade 4 were much better, so I appreciate you taking the time to respond. Who ever takes a vehicle for a spin only to check the headlights? I'm going to have to get some high-quality bulbs and see if it helps, because I didn't think a 5-year-old car would have subpar ones. Quote Link to comment Share on other sites More sharing options...
johnmayerrr Posted 4 hours ago Author Share Posted 4 hours ago 🙂 Quote Link to comment Share on other sites More sharing options...
nicebubby8 Posted 4 hours ago Share Posted 4 hours ago For extra-bright halogen lights, be sure to check their rated hours. They could be something you swap out frequently. Quote Link to comment Share on other sites More sharing options...
ENVIOclev Posted 4 hours ago Share Posted 4 hours ago verify their proper alignment first. Verify that the headlight adjustment is in the ZERO position. For the money, upgraded halogen lights are a great choice. Purchasing a brand-new set of LED headlights that meet all four specifications is the only method to legally use LEDs. Reason being, in the UK, it is not permissible to retrofit your existing headlights with high-intensity discharge (HID) or light-emitting diode technology. Quote Link to comment Share on other sites More sharing options...
torque2me Posted 4 hours ago Share Posted 4 hours ago My 2022 HEV (before the facelift) had headlights that I wasn't too fond of, especially the dip beam. I used Osram Nightbreaker HB3 light bulbs as a replacement. Even though they weren't at all like the HID/halogen setup on my old Saab 9-5 Aero, the noticeable difference made them tolerable. Quote Link to comment Share on other sites More sharing options...
torque2me Posted 4 hours ago Share Posted 4 hours ago 🫠 Quote Link to comment Share on other sites More sharing options...
