brakes for 508 pse
The cost to repair the 508 PSE hybrid's front discs, pads, and callipers (ALCON) is five thousand pounds. Not only is it prohibitively expensive, but the left calliper is also unavailable. Could another combination of pad, disc, and calliper work? Want the cheapest fix because the car has 110k miles. I am grateful.
If there is a problem, could you please replace the calliper pots and seal?
It is reasonable to assume that the calliper slides can also be swapped out.
It is more common to purchase aftermarket discs and disc pads instead of OEM ones.
Why isn't repair an option instead of the current assumption that replacement is the only option? Could you please clarify the exact nature of the problem?
Are the calliper assembly OEM part numbers available?
