N43 gets stuck
NevoBMW320i
Consequently, while swapping out the 116i's cylinder head, I somewhat ruined it.For months, I have dabbled with this, doing little things here and there.
Over the weekend, I made the decision to fit the head. It didn't occur to me to install the non-return valves onto the block until after I had fitted the new gasket and rigorously torqued all the bolts in the correct sequence. What a dweeb!
Could I just swap out the bolts and head for new ones, install the valves, and then swap out the head for the same gasket? Or would I also need to get a new gasket?
Much obliged.
