Rough Idle and Start-Up on BMW e81: Fuel Injector?
DMGRS
Hi everybody, Last night I was going home when my vehicle abruptly lost all power and I had to have it towed. After a restful night at home, I checked on my vehicle early the next morning and discovered that it starts but has a harsh initial idle before settling down. Seems to vibrate when accelerated (video link added below). I performed a basic running test with ISTA and noticed that cylinder 2's fuel readings were significantly different from the others (picture).
I'm not sure what the problem is, but I removed the injector and it still ran the same, so I'm keeping my fingers crossed that it's just that. I'm crossing my fingers that it isn't rod knock.
This noise reminds me a lot of diesel knock, however a few years ago on my N47 I discovered it was the fourth large end. It sputtered because the large end had so much play, throwing off the timing on that cylinder.
I would try removing the injector from cylinder 2 and plugging it into cylinder 1, starting the engine again, and reading the injector readings to see if they change.
