stevenkeyte Posted July 9, 2024 Share Posted July 9, 2024 Greetings, I am seeking viable alternatives to soldering in order to access a positive wire. This is intended for audio applications. I have obtained the primary power wire for the head unit command. I used posi-lock, but, the connection seems to be rather uncertain for an unknown reason. Fortunately, I have a couple crimp splice locks readily available. Do you have any recommendations? Quote Link to comment Share on other sites More sharing options...
SD1too Posted July 9, 2024 Share Posted July 9, 2024 Do they seem satisfactory? Quote Link to comment Share on other sites More sharing options...
SD1too Posted July 9, 2024 Share Posted July 9, 2024 https://www.ebay.co.uk/itm/392764770425?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=4wWUOKnCQr2&sssrc=2047675&ssuid=g1NaSSleQ9O&widget_ver=artemis&media=COPY&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338181125&toolid=10001&customid=2518X1570512X13485eb31b04a38c8eb521f06d754df3 Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted July 9, 2024 Share Posted July 9, 2024 I have a preference for soldering and using heatshrink, but I am also really enthusiastic about using Wago 222 series cage clamps. https://www.expertelectrical.co.uk/wago-222-series-wiring-connectors?utm_source=adtraction&utm_medium=partner&utm_campaign=adtraction&at_gd=A0094408F8A4B17DAA3FCCDBA5427BA55AD5DCA8 Quote Link to comment Share on other sites More sharing options...
rab60bit88 Posted July 9, 2024 Share Posted July 9, 2024 I am also present here. An excellent, hassle-free alternative for upkeep. 👌 Quote Link to comment Share on other sites More sharing options...
nickoyster4 Posted July 9, 2024 Share Posted July 9, 2024 The Wago 221 connectors are of smaller dimensions. Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted July 9, 2024 Share Posted July 9, 2024 Indeed, it is quite likely that it is even more appropriate for automotive applications.👍 Quote Link to comment Share on other sites More sharing options...
nickoyster4 Posted July 9, 2024 Share Posted July 9, 2024 Wago connectors are an optimal option for automobile connections due to their ability to withstand vibrations without compromising the spring pressure on the wires. Quote Link to comment Share on other sites More sharing options...
motorman3 Posted July 9, 2024 Share Posted July 9, 2024 However, they cannot be integrated into an existing wire by splicing. Quote Link to comment Share on other sites More sharing options...
nickoyster4 Posted July 9, 2024 Share Posted July 9, 2024 Sever the cable, remove the insulation, insert one end into one hole and the other end into another hole, and connect to a third hole by tapping. Job well done! Quote Link to comment Share on other sites More sharing options...
WanderlustGuru Posted July 9, 2024 Share Posted July 9, 2024 Connect a wire from a nearby fusebox, such as the one located outside the entrance pillar, using a piggy back fuse connection. There is no need to physically cut any wires. Quote Link to comment Share on other sites More sharing options...
WhisperingWillow Posted July 9, 2024 Share Posted July 9, 2024 Is this an accurate representation? Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted July 9, 2024 Share Posted July 9, 2024 I am not really like of those 'Scotchlok' type splices myself, but I must agree that they are convenient to use. Quote Link to comment Share on other sites More sharing options...
