The error code that is being shown is "Turn signal left mirror."
TechnoTrailblazer
The left-hand side door mirror indication on the 2007 petrol C180 komp w203 model is not functioning. Even in instances when danger warning lights are on. The functionality of the indication light has been verified by testing, specifically with the right-hand side (RHS) being confirmed as operational.
Does this imply the presence of a discontinuity in the wire? Upon visual inspection, I have seen that the wires seem to be in satisfactory condition, based on the limited visibility provided by the removal of the mirror cover. I encountered a state of perplexity when attempting to get a voltage measurement with a multi-meter.
Furthermore, my attempts to locate a switch relay have proven to be fruitless. Is there a single entity or concept that fulfils the criteria being discussed?
Indeed, the internal components of my earphones were consistently dysfunctional without any visible harm to the insulation. However, it is rather evident which ones are faulty when they are bent. The practise of consistently folding the mirrors by my spouse while parking exacerbates the matter.
As previously mentioned, the wiring in the mirrors tends to develop cracks over time as a result of fatigue caused by the repetitive folding and unfolding of the mirrors. The repair was conducted under the Approved Used warranty on our 203 model.
It is plausible to speculate (and maybe even want) that contemporary vehicles, such as our present-day 205 model, use slip rings or other mechanisms instead of wires that flex back and forth in order to facilitate the automatic folding of mirrors.
I would like to express my gratitude to all those who have graciously dedicated their time to respond to my inquiry about the malfunction of the door mirror indication. It is quite probable that there exists a discontinuity in the wire.
Could someone provide clarification on whether the wire in question extends directly from the mirror through the door, or whether it instead connects to a junction located behind the door panel?
The response was prompt. Remarkable.
The vehicle in question is a 2007 C180 komp C class, which may not be equipped with the aforementioned "piece of trim." Upon careful examination of the door panel, I proceeded to remove the uppermost section of trim, which concealed a speaker. However, I saw that there was no discernible connection present, save from the harness cabling originating from the mirror. The door is equipped with a substantial lower trim that conceals a larger speaker. I am hesitant to proceed with the removal of this item until I have concrete evidence that the mirror connection is the underlying cause.
One possible approach to addressing the issue involves replacing the whole loom. Alternatively, it is feasible to tactually identify the location of the damaged component, then sever the wire, rejoin it, and insulate the connection. It is important to note that all of these actions should be performed inside the confines of the mirror housing.
