Open my trunk, please.
neilrr010
I just got my e46 330i back from the mechanic, but it was dead and I didn't have the key fob (just the valet key). The cherry on top isn't having to get into the trunk, though. The negative terminal was disconnected by my mechanic. Can I crack it somehow?
I attempted to connect a portable jumper with a 1250A rating to the wires under the hood, but alas, it was unable to detect the battery, so it remained inactive. I even attempted to overwrite it. It would have worked if the battery terminals were connected, but I'm stuck without a master key fob and the negative terminal isn't connected.
You will need to disassemble and remove the right-hand bootlid light if you do not have a key or 12v. To open the boot lid, push the carpet inwards, then locate the cable that operates the latch to the left of the hole. Give it a good tug and the lid will open.
