neilrr010 Posted October 22 Share Posted October 22 I just got my e46 330i back from the mechanic, but it was dead and I didn't have the key fob (just the valet key). The cherry on top isn't having to get into the trunk, though. The negative terminal was disconnected by my mechanic. Can I crack it somehow? Quote Link to comment Share on other sites More sharing options...
neilrr010 Posted October 22 Author Share Posted October 22 Amazon.co.uk : BMW 330i Quote Link to comment Share on other sites More sharing options...
neilrr010 Posted October 22 Author Share Posted October 22 Amazon.co.uk : car battery Quote Link to comment Share on other sites More sharing options...
KOOLCAR Posted October 22 Share Posted October 22 If you happen to have jumper cables and an additional vehicle on hand, you can power the locks by linking the downer car's battery to the E46 jump points located under the bonnet. Quote Link to comment Share on other sites More sharing options...
neilrr010 Posted October 22 Author Share Posted October 22 I attempted to connect a portable jumper with a 1250A rating to the wires under the hood, but alas, it was unable to detect the battery, so it remained inactive. I even attempted to overwrite it. It would have worked if the battery terminals were connected, but I'm stuck without a master key fob and the negative terminal isn't connected. Quote Link to comment Share on other sites More sharing options...
KOOLCAR Posted October 22 Share Posted October 22 Odd, because I've done the same thing without the battery. Quote Link to comment Share on other sites More sharing options...
paulh2602601 Posted October 22 Share Posted October 22 It should work; maybe there's a diesel setting that would be useful, but I'm not sure if you had a good connection with the jump pack. Do you not possess a key that can start the vehicle? because the e46's boot/trunk key is that one. Quote Link to comment Share on other sites More sharing options...
DMGRS Posted October 22 Share Posted October 22 You will need to disassemble and remove the right-hand bootlid light if you do not have a key or 12v. To open the boot lid, push the carpet inwards, then locate the cable that operates the latch to the left of the hole. Give it a good tug and the lid will open. Quote Link to comment Share on other sites More sharing options...
