Problems with the 2013 D4F Clio
Starcar2022
Hi there! At the moment, my 2013 Clio's D4F-722 engine is giving me trouble. Even after multiple investigations, the problem remains unresolved.
Then, what exactly is wrong? Just as the engine is getting hot, misfiring will begin abruptly. Aside from the misfire event's recorded DTCs, the MIL begins flashing and the wrench and ESP symbols light up. If you rev the engine past 2500 rpm, it will run smoothly again and the MIL light will not flash. Be aware that the engine starts misfiring the second the revolutions per minute (rpm) drop below 2500 rpm, but gains power instantly at that point.
How the car won't misfire "logically" is another strange thing. It might begin misfiring as soon as it warms up, or it could start 30 kilometres later. When the engine is misfiring, you can fix it for X amount of time by turning it off and then back on again.
What other people have done or substituted:
Array of coils
End caps
Measurement of crank position
Resistance measurement of plug leads
My accomplishments:
Valve adjusting
Gaskets that cover valves
Gaskets used on intake manifolds
As it begins to malfunction, there are a few DTCs that can be recorded:
Misfire in Cyl 1
Problem with Cyl 3
Found a misfire while fuel levels are low
Fumes from pollutants
Occasionally, while driving normally, you might hear a "Pollutant misfire" or "Cyl 1 or 3 misfire" even though the MIL isn't flashing or the engine isn't running rough.
It seems to reason that we should start searching for an electrical component since the RPMs have such a significant impact on the misfires. After the engine has cooled down tomorrow, I will check the valve clearances again.
This is just a brainstorming session, so please accept my apologies in advance if the post is badly worded.
Please verify that this is a coil pack and not a set of pencil coils.
Since you've already replaced the pack, it's unlikely that it's a breakdown, but if you're still seeing misfires on 1 and 3, it could be an issue with the electrics that are powering the pack.
When the spark plugs were removed, how did they appear?
Were the spark plug wires replaced? You said you were going to check them.
Is a scan tool an option for checking the fuel trims?
Is it possible for you to verify that each cylinder's compression is equal?
Did the symptoms improve or worsen after you changed any components?
Since I did not replace the plugs, I am unsure about their condition. I seem to recall hearing that one of the plugs was missing its tip, but I can't place it.
I agree that the lack of replacement for the spark plug leads could be the source of the problems. All of their cylinders have a resistance of 2.2 kohms.
There was real-time information for "Richness correction" in my scantool (Autocom). Depending on the throttle position, the value ranged from about 0.7% to 1%.
We will take compression measurements tomorrow.
My understanding is that, with the exception of the plug missing its tip, none of the new parts are significantly different from the old ones.
When replacing a coil, wire, and plug, do it all at once. Wear and tear on the wires and spark plugs can ruin even a brand-new coil. If the wire is internally brittle or behaves up when heated, resistance won't reveal it.
A fuel delivery problem is probably not to blame for the lean or rich misfire, since 1% is excellent.
The missing tip is something that would worry me. Hopefully, it just blew the exhaust and spared the engine from any harm.
I'd swap out the coil pack and wires, or at least use a known good one, and start over. You should also double-check the coil's low-voltage wires and connector.
