BENZE220AMG Posted September 22 Share Posted September 22 Greetings, I now own a 2018 W205 C220d 4MATIC. Purchased second-hand wheels from C43/450, which had the following dimensions: Front - 7.5Jx18 ET33 Rear - 8.5Jx18 ET49 The rears are OK, provided they fall within the manufacturer's specified range. I am perplexed by the fronts. The manufacturer specifies that the permissible offset range is between 42 and 46, however mine measures 33. Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted September 22 Author Share Posted September 22 Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted September 22 Author Share Posted September 22 I am uncertain if I will have any issues installing the new wheels with an ET33 offset. Will it adversely impact the 4MATIC, posing any hazards to it? Will it also impact the driving in any manner? I appreciate your assistance in advance. Quote Link to comment Share on other sites More sharing options...
WanderlustGuru Posted September 22 Share Posted September 22 The new wheels with an offset of 33 will protrude 10mm more than the appropriate ET of 42 - 46. Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted September 22 Author Share Posted September 22 That is not the question I posed. Quote Link to comment Share on other sites More sharing options...
Gianni682 Posted September 22 Share Posted September 22 Indeed, that was somewhat the case. Quote Link to comment Share on other sites More sharing options...
Gianni682 Posted September 22 Share Posted September 22 33mm will protrude beyond the advised dimensions. Most Mercedes wheels are positioned too deeply inside the wheel arches for my preference, necessitating spacers for an aesthetically pleasing appearance; hence, an extension of around 10mm may enhance the visual appeal. Quote Link to comment Share on other sites More sharing options...
BENZE220AMG Posted September 22 Author Share Posted September 22 My primary confusion is to the 4MATIC system, rather than the potential protrusion of the rims from the fender. Quote Link to comment Share on other sites More sharing options...
WanderlustGuru Posted September 22 Share Posted September 22 My primary confusion is to the 4MATIC system, rather than the potential protrusion of the rims from the fender. Quote Link to comment Share on other sites More sharing options...
mrnobady Posted September 22 Share Posted September 22 said that if you invested the time to peruse my content. The front wheels will protrude 10mm more than your current ones. The 4MATIC does not alter the wheel specifications. Quote Link to comment Share on other sites More sharing options...
DenishP4 Posted September 22 Share Posted September 22 The offset will not impact the 4Matic system; however, it may be adversely affected by any discrepancy in rolling radius between the front and rear wheels. If it resembles the BMW XDrive system, there exists a prescribed tolerance. Your insurance company, however, may oppose the concept. While it may be apparent, it is prudent to verify. Quote Link to comment Share on other sites More sharing options...
