The charger for my iPod 10 is not functioning properly.
WhisperingWillow
LM - New Range Rover LS - Range Rover Sport LA - Discovery 4 Title 10MY Land Rover Latest Apple Products not charging
Modified on July 27, 2009 at 08:14. Category: Electrical. Symptom: 207000 Entertainment Systems. Content:
Problem: The newest iPhone, iPod Touch, and iPod Nano models do not charge when connected to the Portable Audio Interface (integrated iPod car adaptor).
Cause: Apple has modified the power supply approach in their most recent models. The impacted goods are as listed:
iPhone 3G
iPhone 3G S
2nd Generation iPod Touch
4th Generation iPod Nano
Instruction: If a client reports that their Apple goods are not charging from the car power source, advise them to buy a Scosche passPORT Car Charging Adapter. You may purchase this item from other vendors or the Apple store by copying and pasting one of the URLs below into a web browser:
Link to the US Apple Store: http://store.apple.com/us/product/TS696LL/...MjIwMTg2NQ
UK Store link: http://store.apple.com/uk/product/TS696LL/...Mjg0NjU4Mw
Apple has implemented this modification on their devices, and customers are responsible for purchasing the adaptor.
Land Rover engineers are now developing a solution, which will be the topic of a future message.
Thank you for sharing. I now understand the reason why my iPod and iPhone are not charging. You cannot revert to previous versions of the Apple software/firmware.
The issue also occurs with the iPod dock installed in my MY08 TDV8, indicating that it is not exclusive to MY10 integration.
Update: The Scosche PassPORT Car Charging Adapter is available with two different production dates, which are indicated on the packaging. Both models have the same model number and very similar appearance, making it difficult to distinguish between the two. Ensure that the adapter you are buying is from 2009. A forum user on rr.net reported that an adapter from 2008 would not charge his iPhone.
My 4th generation iPod Nano is not charging, despite the handbook stating that it should. Shouldn't LR be responsible for resolving this issue at their cost? My automobile is a MY10 RRS TDV6. Additionally, when I turn off my vehicle, it does not turn off my iPod, causing it to entirely lose power by the time I leave the workplace.It is unusual that my Jaguar XK, which is just 7 months old, does not charge it! Using the USB connection and the included Apple PC lead charges the iPod but does not allow it to play. Quite a troublesome situation.
There are several issues with the iPod charger. When you get a new iPod for Christmas, be sure to closely monitor it while it is charging and updating for the first time. It is recommended to charge the device for many hours to guarantee proper calibration. However, when setting up a video iPod to present to someone, I discovered that it had stopped charging after transferring all the tunes, indicating potential issues with new goods.
If this problem has been resolved, can someone specify the components I need to replace on my early 2010 RRSSC to enable my iPhone/iPod to charge while in use?
I purchased the Scosche PassPORT adapter, which initially functioned fine. However, due to its design causing the iPhone to extend beyond the centre console's storage space, the connection on the Scosche grew loose and unstable over time.
