QuirkyPixel Posted April 16 Share Posted April 16 Greetings everyone! Under the lower weather stripping of the driver's side rear quarter panel window, I can see the first indications of rust on my 2924 PHEV Premium. Do you see any more symptoms like this? I'm worried it will become worse over time, even if it's not a big deal today. Quote Link to comment Share on other sites More sharing options...
Rudy7831 Posted April 16 Share Posted April 16 Is rust really the only explanation? I don't see rust running onto the rubber and plastic; it seems like something else entirely. Find out if it comes off. Quote Link to comment Share on other sites More sharing options...
QuirkyPixel Posted April 16 Author Share Posted April 16 Removes stubborn stains. Quote Link to comment Share on other sites More sharing options...
MidnightMarauder Posted April 16 Share Posted April 16 There is a corrosion warranty on your vehicle. The distance is endless, but it's measured in years only; I've forgotten the name. Quote Link to comment Share on other sites More sharing options...
honeycut_mazda5 Posted April 16 Share Posted April 16 It may be rail dust, which is evident on white cars and is frequent with Mazda. To remove it, a clay bar is required. You now know the answer if it is compatible with clay. Quote Link to comment Share on other sites More sharing options...
vitessear3 Posted April 16 Share Posted April 16 On top of that, I have a few at the front hoodline. Quote Link to comment Share on other sites More sharing options...
mrnobady Posted April 16 Share Posted April 16 Using a clay bar isn't the only option; there's also a much easier and more effective one. A microfibre detailing clay cloth and iron remover are all that's needed. While I like to utilise do-it-yourself detail supplies, you can save money by purchasing these options from Walmart: Meguires - Towel for Detailing Clay with Microfibre Surface and Iron Remover If the iron is embedded in the Clear Coat, washing the automobile will help remove it and prepare it for attacking the surface. Before lightly cleaning the car's surface, spray the stained area with waterless wash. Next, spray the rust spot with one spray of Iron Remover. Finally, spritz the clay cloth with one spray of Iron Remover. Just drag the towel over the surface without pressing down; the Iron Remover will do the rest. Scratches can be caused by rubbing or applying pressure with the towel. To remove brake dust and any other iron particles from a car, this approach is both easy and efficient. You may use this spot remover to the spaces behind the wheels and the wheels themselves when you've mastered eliminating this spot. The amount of brake dust and iron particles found on many automobiles' surfaces will astonish you. Every year when I detail my autos, I utilise this process, and the finish looks brand new again. Quote Link to comment Share on other sites More sharing options...
WanderlustGuru Posted April 17 Share Posted April 17 🤩 Quote Link to comment Share on other sites More sharing options...
