Doncaster34 Posted October 28 Share Posted October 28 Hi there, Driven by an AMG-pack 2012 E250 CDI S212 waggon. An odour of burning rubber has been detected both indoors and outdoors as of late. So that I can see the strut towers free of rubber dust, I make sure my engine compartment is always clean. The 'touch the pulleys' test popped into my head after perusing all the clues provided by META AI (which is pretty good). My finger burnt on the water pump pulley, but the others were all nice and toasty. This is what I'm calling an intermittent problem that will eventually become a full-blown breakdown. This is the vacuum-activated pump. Even though the temperature gauge occasionally climbed one tick higher than usual, there was no overheating. Is my diagnosis correct? When you lose your belt, you might reach out and grab anything you can get your hands on as it winds up. Trust me, I know the feeling. I would prefer that not to occur. For the next 270,000 kilometres, apart from the pump and belt, what other parts should I replace to make sure it runs smoothly? We gladly accept the opinions of those with more experience. It is appreciated. Quote Link to comment Share on other sites More sharing options...
Ken_Lion Posted October 28 Share Posted October 28 Some problems that can arise in OM651s after 100,000 miles or more include: gasket leaks or warped rocker covers; oil cooler leaks caused by failed seals; diesel filter housing leaks caused by brittle plastic pipes; inlet manifolds that start giving trouble; and last but not least, engine timing chain stretch, which is indicated by chain rattle-on-cold-start. Also, EGR coolers can become clogged. You could choose to get everything done at once so it's perfect, or you could fix or replace things as they break. For example, when my inlet manifold leaked oil, I had to remove the diesel filter housing and replace it at the same time. In my opinion, the two most important things are to change the oil at the intervals specified by MB (I change mine every 6,000 miles) and to inspect everything on a regular basis. The reasoning behind this recommendation differs from MB's 40K mile recommendation; according to another piece of advice I read recently, diesel filters should be changed every 20,000 miles to avoid injector problems in engines with higher mileage. Quote Link to comment Share on other sites More sharing options...
xsports Posted October 28 Share Posted October 28 In most cases, the water pump will be dangerously hot to the touch; after all, the shaft you touched was carrying water that was almost boiling. Any diagnosis I make will be based on speculation unless I see it. I hope it works out. Quote Link to comment Share on other sites More sharing options...
Doncaster34 Posted October 28 Author Share Posted October 28 I have ramped up the maintenance plan. Each 6,000 kilometres, I change the oil and filter. Every time it's necessary, I change the air filter, cabin filter, and diesel filter by myself. Replaced filters are not my speciality. At this very moment, I am waiting for the garage to finish their diagnostic. I just swapped out the valve cover. Even without the code, I can tell that injector 4 isn't ideal. It seems to me that the intake system might have a tiny leak as well. I am unable to isolate the hiss. Instead of using hydrogen, I'd prefer a thorough disassembly and manual cleaning for my intake. Two of my friends have rave reviews in that area. Regardless, I'm at ease in the waiting room, where there are an unusually large number of attractive women. I will fix the steering rack after I fix all the motor issues. No amount of adjusting has ever corrected the tiny pull to the right. Finally, the rack could be an option. I'm going to start with a fluid change. Quote Link to comment Share on other sites More sharing options...
Doncaster34 Posted October 28 Author Share Posted October 28 The decision has been made. The location was correct, but the pulley was incorrect. That one is pricey. There is a little play in the crankshaft pulley. Two quotations will be written by them. Typically, the optimal option is to use one for the water pump and complete set of pulleys and one for the crankshaft pulley and belt. The choice will be made based on price and the timing of Christmas. To be honest, the kids have been misbehaving the whole year. 😆 Quote Link to comment Share on other sites More sharing options...
mrnobady Posted October 28 Share Posted October 28 Possibly the alternator clutch pulley Quote Link to comment Share on other sites More sharing options...
Doncaster34 Posted October 28 Author Share Posted October 28 Now we have the quotes. The essentials will set you back 1,150 euros, while the complete accessory drive, water pump, and labour will set you back 1930 euros. A lot lower than what I had anticipated from my study. I intend to take the full course. If I had to wager, I'd say my vehicle has the best maintenance records for its year, model, and mileage in the nation. Love comes at a price. Occasionally, OEM parts are the superior option, even though I could find them elsewhere for half the price. Also, make sure to check out the hostess! Heaven on earth! Quote Link to comment Share on other sites More sharing options...
xsports Posted October 28 Share Posted October 28 Is the belt and crank pulley the only components costing €1,150? around £962 in today's money). Too much for what appears to be a straightforward task. Perhaps they included that quotation to make the larger one seem more credible. The whole thing takes around 90 minutes and costs £200. Quote Link to comment Share on other sites More sharing options...
ENVIOclev Posted October 28 Share Posted October 28 What gives the crankshaft pulley its slack? How loose is it? Surely there must be some oil seeping out? Quote Link to comment Share on other sites More sharing options...
ENVIOclev Posted October 28 Share Posted October 28 http://shop.ebay.co.uk/?_nkw=crankshaft+pulley&mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5338181132&toolid=10001&customid=2518X1570512X061ef7b6dd753f64f6d80663116d9dbc&subId2=15 Quote Link to comment Share on other sites More sharing options...
Doncaster34 Posted October 28 Author Share Posted October 28 The two parts aren't the only ones. There are a couple more items, but the list is shorter. Idler pulley, tensioner, bolts, etc. The dealer is obligated to adhere to Mercedes regulations. This comes with no spare parts. Plus, labour is expensive. The Belgians. thrice as much as a standalone garage. That area is called Wallon. Every single garage in the area has completely lost my trust. Due to mental exhaustion, the only decent one closed. However, compared to high-quality aftermarket components, the pulley is actually more affordable. They stand firm on the two-year warranty, which is the only perk in my book. Including the subframe, they have dutifully honoured everything. It isn't accurate to say that the pulley is loose. Here we have a pulley/harmonic damper. The structure is disintegrating. It's not easy. In French, I understand everything. Aircraft jargon is my speciality, but automotive lingo is completely foreign to me. Quote Link to comment Share on other sites More sharing options...
mrnobady Posted October 28 Share Posted October 28 They wobble as they wear out; they are rubberised and commonly referred to as torsional vibration dampers. Quote Link to comment Share on other sites More sharing options...
Doncaster34 Posted October 28 Author Share Posted October 28 His words. Quote Link to comment Share on other sites More sharing options...
KOOLCAR Posted October 28 Share Posted October 28 I had the same issue with my 211 E500. Quote Link to comment Share on other sites More sharing options...
